Electric Scooter Needed for Hybrid Concept
Hey there,
A customer read my article in ROBOT about using a small gasoline engine and an alternator to generate power. This customer is really heavy and uses an electric scooter to get around. I imagine it is one of those three-wheel "Lark" type of scooters.·More than once he ventured out and couldn't make the return trip home when he ran out of power.
So he asked me if there's a way to retrofit·the device·with a gasoline engine and an alternator. As I recall, wheelchairs use big batteries so they should be able to handle the current generated by an alternator if they are in a low-voltage state.
But where can I get a motorized·scooter to experiment with? These things are darned expensive.
If anybody has some tips let me know. I'm willing to do the work for free with Parallax parts to see if I could extend the range of one of those devices, but I don't want to buy one.
Ken Gracey·
Ken Gracey·
Just two days ago I picked up an electric wheelchair for free. The kind that has two drive motors powered by two group 24 batteries. It's made to carry 300 lbs a distance (claimed) of 19 miles.
Right now in my area there are two others for sale for less than $300.
Here's just one example;
sacramento.craigslist.org/for/382488859.html
Check with the local hospital and/or nursing homes. They may have a "spare" that they would be willing to lend out for testing and development of the concept. Another source might be the fine folks and MD (Muscular Distrophy).
Also, if you can, find out what specific disease/disability your customer has, and see if their organization might be willing to help you out. If you can get this information, you could try his local chapter, your local chapter, and the national group.
I've PM'd you with another possible option.
John R.
Click here to see my Nomad Build Log
...Tiger
If you haven't found a scooter/cart yet, another source might be a big grocery store, or one of the "big box" home centers. They usually have a few of these available for shoppers, and you may be able to borrow one, even if only for a day or two at a time.
John R.
You could make a data aquisition system with a couple current sensing devices, to test your amp draw and charging capabilities and never have to buy a scooter.
<<==Bill
The real world is not where they rate these scooters at. Though ADA has been the law of the land for 15 years I still find obsticles that were never planned for. Curb cutouts that are unusually steep on a wickedly uphill stretch of street puts me climbing ramps that terrain plus ramp are 30 to 40 degrees above horizonal. A uphill stretch of street bleeds the batteries more quickly. Carpeted floors eat up more battery life. Soft ground like a concert in the park or an air show can leave me looking for a place to plug in after a mile or two.
Even having my emergency cord along is no great relief. I sit for 30-45minutes and gain about 3 level blocks of distance. 1 block or a bit more if it is mildly uphill.
Now imagine an emergency, there is no light rail, or buss service. Your ride has had an accident. How nice it would be to head a couple of miles acros town at top speed, 5 miles an hour, but to be assured you would make it home.
Thank you all. The wheeled community needs your ideas.
Post Edited (D Faust) : 8/10/2007 12:44:52 PM GMT
Bill
Would a tech document from the maker of the speed controller help? It gives diagrams and typical features that are equivalent to my owners manual diagrams.
Email me for the tech document.
Regards
Ray
If it is 12 volt then that is GOOD news. Since most alternators will be setup for 12 volts.
Can you just post the documents here ?
Bean.
Teacher: What is the difference between ignorance and apathy ?
Student: I don't know and I don't care
Teacher: Correct !
www.hittconsulting.com
· Click on the "Post Reply" button, then at the bottom is a button "Attachment Manager" click on that. Click on "Browse" and find your file. Then click on "Upload File".
· Or you can e-mail them to me and I'll post them for you. "forum at hittconsulting.com" (use "@" instead of "at")
Bean.
Teacher: Correct !
A few thoughts on the project so far. Ideally the device would be usable while on the move. This would prevent a carbon monoxide problem where a user parked in a relatively enclosed space because cold or inclemate weather. Is there a chance to replace the diodes in a 12 volt alternator with a voltage doubler circuit? As was pointed out earler most wheel chairs/ scooters have sufficent battery capacity to sink most of a alternators current in a quick charge mode while using the rest to drive down the street. Think clean spill free fuels like the propane cylinder.
(Many trucks use 24V systems... )
What you really want is a 'hybrid' gas-electric system, something like what is used in the Toyota Prius or similar models.
That is, a small engine running at all times to produce electricity both to drive the scooter, and to recharge the batteries. Then when you enter an area where the exhaust or noise is 'undesired', you can switch off the engine, and run just from batteries.
To get this, you need an engine(rated to produce enough power to match the electric motors at a normal 'easy terrain' consumption), a 24V alternator, the charge regulator or relay from the same truck you nick the alternator from, and finally, a small computer to 'keep an eye' on the battery.
You CAN run without the computer, but having one may help with fuel economy.
(I assume that you don't want to bring more gas than necessary.)
Don't visit my new website...
That > is < an electronic speed controller. PWM at 19.5 KHz. The pot adjusts the pulse width.
Rick
I thought the·Wig Wag was the sole controller.
Bill
Post Edited (Capt. Quirk) : 8/13/2007 12:53:30 AM GMT
As for the speed controller, yes it is pretty through in its functions. Regenerative breaking, fault detection, battery monitoring and PWM controll. I especially enjoy the way it scavenges energy with the regenerative breaking.
I believe that I was caught expecting a lot more distance one time I was in a convention hall that had been setup with rugs for sound control. The breaking effect of the rugs left me recharging before I left the convention hall with the show half covered. My stop and start for he exhibits had killed my batteries very early where I was acoustomed to reusing the energy scavenged on each stop.
In convention halls and such, they probably wouldn't like it if you started a gasoline engine...
What about a fuel-cell using Metanol?
http://www.efoy.de/index.php?option=com_content&task=view&id=13&Itemid=56
They claim that it doesn't make more noise than a typical computer...
How about using a new battery technology ? Ni-Mh, Li-po, etc.
I guess there is not such thing a boost converter for that much current (to run the battery down further).
Bean.
Teacher: Correct !
Post Edited (Bean (Hitt Consulting)) : 8/15/2007 5:15:48 PM GMT
(Read: burst into flames... )
Most battery-techs doesn't like the stress and abuse this kind of vehicles pose.
(Most electric cars use Lead-acid)
Besides, even with new tech, he may not get much more than 50% boost, and will still get stranded on the carpets.
A liquid 'supplement' will dramatically increase range without adding too much weight to the scooter.
Gasoline will work OK outside, so if he KNOWS he can do whatever he needs to do inside while running on batteries, that is one solution. (Gasoline is easily obtainable)
Methane fuel-cells are quiet, produces no hazardous wastes(unless someone gets P! O! because of the water-droplets...) but the fuel may be slightly more difficult to obtain.
Propane? I don't know what kind of engines/generators are available, and their characteristics, but big canisters(gallon or more) are awkward to handle, so he may need help with replacing empties with full ones. Small canisters used for camping are nice, but are comparatively bl**dy expensive. (I do a bit of camping... )
That said, a 'friend' of mine - who lived in Florida before - rebuilt his classic Beetle to run a 'trifuel' setup.
(Injection system using gasoline mixed with propane, and also had a catalytic converter for Hydrogen, to give it 'a bit of help' during accelleration. He claimed 146mpg on the gasoline... )
http://www.pepboys.com/transportation/personal_transportation/9485022_pal_pt.html
The smell issue, leakage, and safety issues make me think that a gasoline system would not be usable, but the basic research done on one might make a usable emergency power system available in the future.
Thanks all
