Decoding DCF77
im trying to decode the german time-signal DCF77. It's a signal in which ever second one bit is transmitted by a Pulse of 0,1s for "0" and 0,2s of "1" in second 59 the pulse is left out to sync
on the beginning of new transmission.
I've tried to write some code that displays the length of pulse on VGA but it doesn't work and I don't know why.
Thank You for Helping
pri bitout | tick, tick2, dcf, bit dira[noparse][[/noparse]14]~ text.Start(16) text.out($00) text.out($22) repeat text.out("a") 'text.dec(bit) bit:=0 text.out("b") repeat dcf:=ina[noparse][[/noparse]14] text.out("c") mSdelay(1) bit++ text.dec(bit) until !dcf repeat dcf:=ina[noparse][[/noparse]14] ' bit:=0 until dcf ' text.dec(bit) text.out($0D)
as you can read in the manual on page 272
Bitwise NOT ‘!’
The Bitwise NOT ‘!’ operator performs a bitwise NOT (inverse, or one’s-complement) of the
bits of the operand that follows it. Bitwise NOT can be used in both variable and integer
constant expressions, but not in floating-point constant expressions.
Each bit of the two operands is subject to the following logic:
Table 4-14: Bitwise NOT Truth Table
Bit State Result
0 1
1 0
Example:
X := !%00101100
The above example NOTs %00101100 and writes the result, %11010011, to X.
Bitwise NOT becomes an assignment operator when it is the sole operator to the left of a
variable on a line by itself. For example:
!Flag
This would store the inverted value Flag back into Flag.
Be careful not to get Bitwise NOT ‘!’confused with Boolean NOT ‘NOT’. Bitwise NOT is for
bit manipulation while Boolean NOT is for comparison purposes (see page 274).
so your "until !dcf" will invert the value of dcf and then the value is evaluated for the "until"-condition
i haven't testet it on the propellerchip but try
"until dcf == 1" using "==" makes a comparison without affecting the value of dcf
ATTENTION you HAVE to use double"=" "=="
a single "=" gives dcf a new value and then the new value is evaluated for the until-condition
Using a state machine, each second is divided up in 10 ms intervals. Using these intervals the pulse length is decided upon and acted on accordingly.
Typically you only need to modify 'CDcfIn', 'CDcfOut' and 'CDcfLevel' if different hardware/connections are used.
I know it is not direct answer to your question, but the state machine approach is a relative easy way to detect the pulse length.
The code contains some debug information which can be used to show the realtime acquisition of the DCF signal (e.g. GetBitNumber / GetBitLevel / GetBitError).
Besides the DCF77 decoder code, there is also a LCD driver (character LCD, 4/8 bit parallel access) included, mainly because it is used by the demo code.
It should be possible to remove all LCD code from the DCF77_demo code to make it work with only the TV output.
@Robert: I remember I had problems with the output of my DCF receiver, bought from the popular Reichelt shop
(a) You must not connect the ON ("ein") pin, neither to ground nor to Vcc, the receiver worked only without any input
(b) Signals turned out to be +/- 1,5 V rather than 1 to 4 V as documented (@ 5 V supply)
(If I remember this correctly...)
Have you checked with a 'scope?
Post Edited (deSilva) : 7/30/2007 6:38:53 PM GMT
Thanks for helping me to remind me what's standing in the Manual·;-)
I've read that, but then... forgot it again
@ Marcel
Nice, probably working objekts, if I don't make it writing my own,
·because thats what i'm trying. Just for exercise. If I'm done or completly
frustrated ;-) I'll have a look.
@desilva
Hehe^^
Jepp the reciever from Richelt...
After my first code didn't work, I started searching the mistake.
a) It's correct no input at all.
b) I tested if the Propeller would accept the levels of the reciever with some code that
·shows the input of the reciever on anouther output: it does. but could be that the pulse ist'n
recognized as one pulse but is close to the threshold. But the Ozzi is somewhere behind my bed.
So far, far away. but I'll check it tomorrow.
