PSC , AVR and HS 422 trouble
I have almost tried everything..
I am Using an AT90S8515 with a BASCOM avr code (BASIC) and a bunchof HS-422 servos..
Even though green light on the PSC blinks at the exact intervals according to the code, the servos dont move to the positions..
They get stuck at probably the default position and dont budge..
The code is :
The crystal is fine the circuit is fine as the green light blinks.. the power should be fine because I am using 6 pack NiCad 1500mAh batteries or a 10 Amp variable voltage source..
Please help ..
Rao
The code is :
Dim Ch1 As Byte
Dim Pw As Word
Dim Pw1 As Byte , Pw2 As Byte
Dim Ra As Byte
Dim Car As Byte
Dim Ba As Byte
Ra = 7
Ch1 = 1
Ba = 0
Car = &H0D ' HEx representation of Carriage Return 0D
Print "!SCSBR" ; Ba ; Car
Do
Pw = 350
Pw1 = Low(pw)
Pw2 = High(pw)
Print "!SC" ; Ch1 ; Ra ; Pw1 ; Pw2 ; Car
Waitms 2000
Pw = 700
Pw1 = Low(pw)
Pw2 = High(pw)
Waitms 2000
Loop
Please help ..
Rao
And all of a sudden the motor on channel 1 starts to run to a position it cant reach..(when I press reset on PSC)
Probably my problem was that I didnt make common ground for motor and uC and PSC...
Do you guys think Hitec HS 422s have pulse widths different from other servos?? i.e. not the usual 1ms-2ms Pulse width..
I am trying to find out on the internet if it is so.. if someone else has the link or the data, please help me out..
Rao
