Deciding on a Platform
So I'm sort of a newbie when it comes to microcontrollers and such. I've programmed some proprietary setups using motorola chips in C via a mechatronics class I took for my undergrad coursework last year. I'm relatively well versed in C, Java, and VB, and am relatively knowledgeable with regard to electronic design for a Mechanical Engineer.
Basically I'm trying to get more familiar with microcontrollers via some projects I'd like to work on independently and was hoping to get some feedback on which platform you guys think would be best for me to start off with.
I had originally narrowed my list down to PIC and AVR. But recently I became aware of the propeller chips and thought they might be a viable alternative to either the PIC or AVR given the multiple COG structure and libraries for video and such. I realize there are easier choices to become familiar with microcontrollers but I'm a quick learner and prefer to get my hands dirty/invest in something that's most flexible.
So I guess people here are probably going to be somewhat gung ho on the Propeller chips but what are some advantages to the chip over the AVR chips in particular. I realize the propeller chips are more expensive but that's not really a big deal seeing as how either chip would be under $20.
Some projects/capabilities I'm looking to work on/with are:
Video output
Motor control using PWM
Sensor readings using A/D converters and serial
Running stepper motors
Running servos
Building a feedback control system for a self balancing robot setup (would the propeller be fast enough for this?)
Building a CNC
Building some sort of robotics platform
Also I see that a lot of mentions of EEPROM being interfaced with the propeller chips, is this because they generally don't have enough space to store the average project compiled in SPIN? Also are the libraries available/guide on how to do this effectively?
Is the multiple processor scheme difficult to work with?
How difficult is it to interface the chip with devices that work with 5V logic highs for outputs? (for input signals I realize all that is needed is a resistor)
Thank you all in advance.
Video output
Running servos
Building a CNC
Re: EEPROM. The Propeller chip has no persistent memory (like EEPROM), only RAM and ROM. This is mostly because the process (technology) used to make the chips can't be used to make EEPROM on the same chip. There is a boot loader in ROM that will automatically load up to 32K of RAM from either an attached PC or an attached EEPROM. The PC has to be running a program that resets the Propeller, then carries on a specific conversation with the Propeller boot loader before downloading the program. The PC can instruct the boot loader to copy this program in RAM to the attached EEPROM. It can also instruct the boot loader to start either copy of the downloaded program (in RAM or EEPROM). That's how the Propeller Tool (Spin/assembler IDE) downloads a program and can start it.
The multiple processor scheme is not hard to work with. You can pretty much ignore it if you want and just use other cogs as peripheral processors running I/O routines like for a video display, serial I/O, and a PS/2 keyboard and mouse.
It's easy to interface the chip with 5V devices. Most of them require only a 1K resistor in series with the Propeller pin. There's a whole thread (listed as HOW TO SAFELY INTERFACE A 5V SIGNAL TO THE PROPELLER?) on how to do this.
Most of the contributed libraries are in the Propeller Object Exchange which is linked to off the main Propeller Page. Have a look.
There are preexisting examples and contributed libraries for many of the things you want to do.
The Propeller is very fast. In Spin, it can do half-duplex serial I/O at 19.2KBaud with maybe 1/2 page of code. VGA video at 1024 x 768 resolution, mostly text with some small areas of graphics mixed in can be done using 2 cogs and only a couple of resistors for external hardware.
Post Edited (Mike Green) : 7/30/2007 3:27:37 AM GMT
Also, what do you think the propeller's advantages/disadvantages are versus chips like the PIC and AVR are(if you've used them before)?
Thanks Again
Regarding PWM ... There are special purpose counters (2 of them) built into each cog. They're accessible from Spin as well as from assembly and, if you use them for pulse generation, you can control the width to the nearest clock cycle which is 12.5ns with an 80MHz clock. Have a look at the application note on the counters (AN001 ... from the download area off the main Propeller page).
Post Edited (Mike Green) : 7/30/2007 4:14:44 AM GMT
Why do I still use AVRs? One, I don't like surface mount work, and a 40-pin PDIP is huge. I'm working with a company who wants the code secure (at least moderately), so the off-chip EEPROM is a killer on the Prop, and while the delta-sigma ADC of the prop may be nice, I don't fully trust it or my ability to lay things out correctly, and neither do some companies I consult for, so an AVR with internal traditional ADC's is my choice many times.
Now if the application needs a good interface... my choice is simple [noparse]:)[/noparse]
-Martin
StampPlot - GUI and Plotting, and XBee Wireless Adapters
Southern Illinois University Carbondale, Electronic Systems Technologies
-Martin
