propeller memory
I am thinking of using the propeller demo board as a digital voice recorder.· However, the memory on the propeller is limited.· My goal is to record for at least 1-2 minutes or longer if possible.· Is there a way to expand the memory of the propeller?? would the new Data logger module work for this??· any help would be appreciated.· Thanks!!
Prob the easiest: Spark fun electronics (online) sells an SD card module that's easily interfaced with the propeller, maximum speed and memory size depends on the SD card purchased. Also, many members of the forum are very expierienced with the SD card and would offer help should you need it.
Both methods have existing object drivers located in the object exchange on the propellers main page.
E3 = Thought
http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
or try the Propeller SD adapter at ucontroller.com
Brian
uController.com - home of SpinStudio
E3 = Thought
SPI bus, >20MHz, no write delay, single byte write (no pages/banks), unlimited writes.
Max capacity for now - 1 MByte (I believe), and not exactly cheap, but can be a solution for tequired time.
What is the top speed someone has gotten this to go in actual measured transfer speed on the prop?
At 20MHz, wouldn't that mean that you could push somewhere close to 2MB/second to the thing?
The site is www.ramtron.com. And it's widely available - digikey, mouser etc.
I didn't see any references to it on· a forum, so not sure if anybody tried it with the prop.
And since there is no delay between consecutive writes, your 2MB/S assumption seems valid.
