homeowrk board can't do 232 with battery?
Can I not use the basic stamp on the homework board (rev b) to do RS232 com?
I saw somewhere in the a couple of docs that the battery can not be used when doing 232 com, so since the homework board only has a battery connection can I not do 232?
I was even trying to send a single character to hyperterminal multiple times (every sec) to try and test the comms
hyperterminal is getting nothing and when I send data with basic stamp
when I send with hyperterminal I get weird results, hopefully my comm setting are just off.
if I read the help file correct I should be using 11505 as 300 baud 7 bit, no parity, one stop bit. Is this correct?
should I be using the 16pin (this is the debug 232 port yes?) or can I use one of the other i/o's
I was using a 22k ohm resistor in series with the port.
maybe I need to try a different size?
Post Edited (cyplesma) : 7/29/2007 1:06:07 AM GMT
It's often easier to use the debug port since you've already got a 9-pin connector and some RS232 to logic conversion circuitry. If you do use port 16, read the description on the bottom of page 416 and the middle of page 395 of the current Basic Stamp Manual (v2.2). You can also use DEBUGIN and DEBUG to do the same things.
missed the DEBUGIN/DEBUG option I may use those.
I did use the debug / debugin works great, again thanks!!!!
Post Edited (cyplesma) : 7/29/2007 2:03:31 AM GMT
