How to system.out.print/debug to computer?
I'm trying to debug some of my code and I want to add print statements, like the "System.out.print()" on the Javelin or DEBUG function with the BS2. Is there a built in function like that or must it be done manually? I'm looking at the BS2 functions object and it appears that it is done manually there, but are there other ways? Thanks.
I'm new to the propeller!
Post Edited (bulkhead) : 7/28/2007 8:27:38 PM GMT
If you want to use a serial LCD, download the "Debug LCD" object from the Object Exchange
If you want to use a TV monitor, you can use the tv_text object from the Propeller Tool library
If you want to use a VGA monitor, you can use the vga_text object from the Propeller Tool library
If you want to use a PC, download the "PC Debug Test & Blink LED Demo" object from the Object Exchange
Include the appropriate object in an OBJ statement in your program and use it for the display. Most of these
objects use the same names for their output routines with the possible exception of some using OUT() while
others use TX(). These usually have routines for displaying single characters, zero-terminated strings, decimal
numbers, hex numbers, and sometimes binary numbers. Check the source code and demo programs for
examples.
I've often used the Parallax 2.5" TV display and tv_text for debugging while the "real program" used a VGA display.
Graham
E3 = Thought
http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
