Random number — Parallax Forums
Random number
LightfootLightfoot Posts: 228
edited 2007-08-06 01:51 in General Discussion
How to you generate a RANDOM value with a maximum of 200?
  • BeanBean Posts: 8,129
    edited 2007-07-28 13:04
    One way is the just generate another random number if the value is over 200
    DO
    · RANDOM tempByte
    UNTIL temp <= 200
    Or you could scale the value using WORD variables
    RANDOM tempWord
    tempWord = tempWord / 327
    Bean.
    Teacher: What is the difference between ignorance and apathy ?
    Student: I don't know and I don't care
    Teacher: Correct !
    www.hittconsulting.com
  • LightfootLightfoot Posts: 228
    edited 2007-08-06 01:45
    now I am trying to generate a number between 3000 and 7000. I tried the diving trick but I do not think it lets you divide by fractions. IS there any other way?
  • JonnyMacJonnyMac Posts: 9,800
    You can do it like this:
    RANDOM result
    result = result // 4001
    result = result + 3000
    This works because // returns a value from 0 to the divisor minus one. The span between the two values is 4000. Your desired minimum value is 3000, hence gets added to the result of the modulus operation.
