how I gain more current to heat a wire???
i want to heat a wire and I made a proram in basic that will turn on and off automatically one output...but when I put the wire on the output doesn't do anything..and when I connected the wire directed to the power supply it work..but i need to heat the wire automatically with the software... I tried to heat the wire with 2 AA battery (3V) and it works...so I think that· I need more current from the microcontroller.... I measured the voltage at the output and it's 5 volts the same as the power supply..that's why I think is the current....
The human whose name is written in this note shall die.
-Death note
- Rick
- Stephen
- Rick
