Class Project...
I have my class project due in a little over a month...I Work all day and have no time to water my tomatoes...I thought this might be a great project for my basic stamp....I'm going to have to use a better motor though in order to get the water to spash out of the tank....I was wondering if anyone knows whether or not the 4-phase /12 volt motor is continuous rotating?· I basically need a motor to spin when I say to spin and stop when i say to stop....Also i'm going to need to add a timer and the crystal that goes with it....i was thinking that it would be nice to add an LCD and perhaps even a Solar panal.....Is all this possible with the Basic Stamp Homework board???? Also if i do get this project going is their a place that i can down load the info to connect and make it all work???Thanks for the Help....
Nicholas Dudek
Nicholas Dudek
Here is most of it in a nutshell, a solar panel and a submersible pump as one unit. First go to here:
http://www.sciplus.com/index.cfm
then search for item number: 93065
All you will need to do is interrupt the positive side of the solar panel when you DON'T want the pump to operate.
Alternatively, here is a miniature piston pump for less than $ 5.00 USD:
http://www.herbach.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=HAR&Product_Code=TM89PMP5655
Bruce Bates
Thanks for the help...I tried the lind for the 93065...but it isn't quite what I had in mind....I was thinking more of a motor that worked when I gave it a signal too....I think the bottum link might have be what i'm looking for....Could i hook up a solar panel to that and program it the same way??? Thanks again for the help...
~Nick
thanks
~Nick
