BS2 Keyboard connection — Parallax Forums
justmatt83justmatt83 Posts: 6
edited 2007-07-25 15:07 in General Discussion
Hello All, I am looking for a way to use a USB Keyboard and to be able to write info to a lcd screen. Any Ideas on how to do that.
Thanks.
    edited 2007-07-25 03:19
    You can use the Vinculum-based memory stick data logger which is really a USB host (among other things). It can talk to a USB keyboard and a Stamp can control it and write to a little LCD screen like the 4 x 20 serial one carried by Parallax. If you want some other display, the issue of whether you can use a Stamp to write to it depends on the display's controller.
  • justmatt83justmatt83 Posts: 6
    edited 2007-07-25 05:16
    Would the Propeller be able to do this with out a Vinculum?
    edited 2007-07-25 06:18
    Maybe. It's theoretically possible, but no one has written any code to do this and it's non-trivial ... a major project that would have to be done by someone pretty expert in writing low level USB interface code. Frankly, a lot of vendors of USB host systems use a low level USB interface chip of one kind or another because it takes care of a lot of the low level details (like the MAX3421E).
  • D FaustD Faust Posts: 608
    edited 2007-07-25 13:41
    Do you have to use a USB keyboard? Can't the Prop can interface with a keyboard such as with the HYDRA system?
    (Note: I do not own nor have used a prop)
    D Faust
    It's pretty easy to interface a Prop with a PS/2 keyboard and/or mouse. It takes 2 I/O pins and a couple of resistors plus the socket for each (if you use the scheme from the Demo Board ... the Hydra scheme is a little more complicated).
    The difference is that USB is a general purpose medium to high speed I/O bus designed to be used to attach many different I/O devices at the same time ... anything from a mouse or modem to a DVD. The PS/2 bus just defines a simple clocked serial port that's designed for a specific device (keyboard or mouse) and usually can't be used with anything else.
