What is the pulse range for a Continuous rotation parallax(Futaba) servo.· Is it the standard 1.0 to 2.0 ms?·I couldn't find it in the documentation. ·Thanks
D Faust said...
Yes. But most of the effect will be had near the 1.5ms "stop" time.
Make sure you calibrate the "center" point to coincide with 1.5ms. See the documentation section, http://www.parallax.com/dl/docs/prod/motors/crservo.pdf·: "Adjusting the set point for the servo "Using a Parallax screwdriver or an (0x40) size Phillips screw driver. Program the BASIC Stamp® microcontroller you are using with one of the following codes or setup your pulse generator to 1.5 ms at 20ms intervals. Once the pulses are generated and the servo is powered and connected. Insert the Phillips side of your screw driver in to the adjustment port. Once inserted you should be able to turn the internal potentiometer to the left and right. You should see the servo change direction also to the left and right. If not make sure you are making contact with the potentiometer. Warning: do not press too hard you may do permanent damage to the servo. To adjust the potentiometer turn to the left/right until the servo stops turning. Be sure to adjust the potentiometer slowly to in sure you do not pass the set point. If you do pass it the servo will change direction."
Yes, where the "Stop" command is at 750, or 1.5 mSec. This does assume a 'stock' BS2, not a BS2sx or BS2p or some other 'flavor'.
And actually your question is not correct.· The range of a BS2 'Pulsout' command is 1 to 65535.· The range of a command pulse for the Servo is 500 to 1000. ·
PAR
D Faust
Allan, thank you also for pointing that out.
D Faust
