control a exhaust vent with servo, stepper, or other
I would like to control a exhaust vent with a bs2. I’d like the bs2 to monitor the pressure of the exhaust and open the valve accordingly. I have found a product that can control the vent with a small geared dc motor, but it is manually controlled by a push button. Is there a way to monitor the position on this type of vent? Should I switch to a servo or stepper? Is there a servo or stepper that can withstand temps of about 300 F?
D Faust
You could do this with a couple of micro-switches at both extents of the vent position -- one at fully open, one at fully closed. And I assume the speed of movement will be pretty consistent. So move the vent to fully open, then close it for 2 seconds (or whatever) to get half closed.
You could replace the button with a relay-closure. Or even parallel the button with a relay closure.
thats true but i do need to know if the butterfly valve is fully open or fully close so i bon't burn out the motor.
As for what PhiPi said, if the pressure was low you could assume the vent to open, and if the pressure was above a certain point you could assume the valve to be closed.
I think that the microswitch idea would work the best especially in combination with PhiPi's logic. (if you could fit the switches in somewhere)
D Faust
