Building a DS1302 (or 1307) module — Parallax Forums
NewzedNewzed Posts: 2,503
edited 2007-07-26 15:09 in General Discussion
I thought I would pass along a tip on building RTC modules.
The crystal pads and the RTC pads that the crystal connect to are very, very sensitive to residual flux.· The module will set and read the time but it will not advance the time if there is the tiniest bit of flux or moisture present.· I use water soluble paste flux and with water I have an abundance of clean "flux remover".· If yoiu are using rosin flux, the board must be rinsed at least once in new alcohol, preferably twice to ensure that the alcohol is not contaminated.· Even if you are using No Clean Flux, it has to be completely removed.· No Clean may not be conductive, but it is certainly capacitive, and that will kill the crystal oscillations.· The boards should be baked for 30 minutes at 125F after cleaning.
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
  • MigsMigs Posts: 95
    edited 2007-07-26 12:49
    Sid:
    I plugged the ds1302 into a socket, and soldered the crystal to the legs of the socket, and the time does not advance. Should I solder it to the chip itself?
    Migs
    "Sometimes we forget that the world itself is paradise." Douglas Coupland, 'Microserfs'
    "If the doors of perception were cleansed every thing would appear to man as it is, infinite" - William Blake
    "We either make ourselves miserable, or we make ourselves strong. The amount of work is the same." Carlos Castaneda
    "One single grateful thought raised to heaven is the most perfect prayer. " G. E. Lessing
    “How much of human life is lost in waiting.” Ralph Waldo Emerson
    "Men often mistake notoriety for fame, and would rather be remembered for their vices and follies than not be noticed at all.” Harry Truman
    My website: www.intoku.net my e-mail:mreznicek@pretensa.com me:Miguel Reznicek
  • NewzedNewzed Posts: 2,503
    edited 2007-07-26 13:14
    Migs, is this a perf board thing or a regular PC board?· Your crystal should have a load capacitance of 6pf.· Make sure you have the right crystal, and that the solder connections for the crystal have been thoroughly cleaned.
    Can you post a picture of that you have - top and bottom?
    Sid
    Don't have VGA?
    Newzed@aol.com
  • RDL2004RDL2004 Posts: 2,554
    I agree with Sid. Check the load capacitance on the crystal. It needs to be 6pf. The 12pf versions are way more common.
    - Rick
