color separately to every pixel in 1024x768
Do I can in the mode 1024*768 to set a color separately to every pixel? (in a demo color it is possible to set only for tiles)
I want to show out any·picture in bitmap.
*Peter*
As for the case of the TV output the prop generates a series signal throught the 3bit DAC, this is similar for the VGA port, it instead uses (3) 2bit DACs one each for RGB and has the Vsync and Hsync signals attached.
Take a look at what baggers could achieve with the prop and video output in this thread http://forums.parallax.com/showthread.php?p=660936
E3 = Thought
http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
Post Edited (RinksCustoms) : 7/24/2007 5:58:11 PM GMT
The dot clock is 25 MHz giving you 40 ns for one pixel. The hardware support allows 16 Pixels to be shifted out before you have to feed the video register again every 640 ns which comes close to 13 instructions, one of it should be a loop jump and one the waitvid, leaving 10 instructions to address the external memory which has to answer within some 100 ns...
Note that you do not only have to fetch 16 bit, but 32 bits plus 32 bits colour map data, which will take 3 cycles through your 20 bit interface...
Though this is possible, it gives you only 4 out of 64 colours within each horizontal 16 bit group I can imagine however that this will not be a very severe handicap when using an appropriate colour pre-processing (to be done by yourself of course..)
When you really want to have different colours to each pixel, you can quadruple the clock speed and output only 4 pixels per WAITVID cyle, which reduces the loop to 160 ns = 3 instructions. This seems imposiible however! When even 640ns seem to tight for your task, you can use two sync-locked COGs, alternately outputting video frames and computing their value.
You should study the drivers called VGA_HIRES...
Post Edited (deSilva) : 7/24/2007 8:31:59 PM GMT
P.S Notice I said MANY, the reason so is that 1 propellor running at 80 MHZ is way too slow for what your getting at. Perhaps 4 or 5 props would do your job best.
But realize this, this isn't exactly what the Propellor is meant for, but, it doesn't mean it can't be done or shouldn't be.
Realize that I am really a mad scientist··· and
Don't forget it!
http://raydillon.com/Images/Illustration/GameArt/WildIsle/WildIsle-Ink-ScientistClose.jpg
Post Edited (Bob the Builder on a C64) : 7/25/2007 7:51:14 PM GMT
