Problems with drivers/basic stamp. Help please!
I have all drivers installed correctly and all the hook-ups are correct yet but for some reason when I plug my Homework board into my computer using the CORRECT serial cord it tells me that the port is already in use and that I can't use it. Can somone help me? Is there some way to get the program on the basic stamp to stop running?
Post Edited (Chase) : 7/24/2007 2:59:08 AM GMT
Are you using a USB to serial adapter?
If so go to your control panel and delete the serial port in conflicting with the USB adaptor. Or change it's port assignment.
D. A. Wreski
Post Edited (Chase) : 7/24/2007 2:36:34 AM GMT
- Stephen
Update -- disconnect everything else from the USB.
Oh, by the way, in the future try using a more descriptive thread title with fewer capital letters. You'll get more help more quickly. Update: Ah, that's more like it!
Post Edited (Phil Pilgrim (PhiPi)) : 7/24/2007 3:11:35 AM GMT
The most common reason we’ve seen for Port in Use errors in Palm-Pilot/PDA Software on the PC such as Active-Sync or Hot-Sync. Whenever these programs are running they take over any available COM Ports scanning for these devices. Do you have this type of software installed?
