RPM reading using a Hall sensor
I was looking at the article here.
http://www.parallax.com/html_pages/robotics/machining/RPM_display.asp
I was wanting to do the same thing and update my CNC spindle, but it looks like he has the magnet on center of the spindle.· I don't understand how the unit would give pulses if the magnet is just spinning, on the current spindle I have they put a magnet mounted onto the pully on the side and it passes by the sensor.
I read the sheets and it looks like it shows it picking up differences in material and not a magnet.· I'm pretty confused.
Russ
Russ
On a round magnet the outside edge will give you the necessary pluse. Half of the outside is North and the other half is south. So, the sensor must be placed off center to get the required input.
D. A. Wreski
Russ
The magnet can be mounted to the surface of the spindle, resesed or covered by a non ferrous material.
Count works real well if that's the only thing your doing, besides displaying it on an LCD. If not Bean wrote some good code for the SX, that's based off only a single revolution, it's in the best sx threads.
Bill
btw, the hall goes low·as it passes·the magnet.
