SD Card Buffer
Hi all,
I have a vs1002 mp3 decoder and a sd card hooked of to my propeller, and I am trying to play the mp3 files from the card.
The problem is that I can't read the data off the card fast enough for the mp3 chip. So I need some way to buffer the data form the sd card. But I don't really have any idea how to go about it.
So does anybody have any hints or code examples for this kind of thing?
-Kit
-Kit
Are you using Rokicki's code ? If so, read 2048 bytes at once with "sdfat.pread", you will get about 400Kbytes/sec if your card is enough fast.
I think that is enough fast to play almost all mp3 files !!, but I never try that.
Regards.
Alberto.
I just tried using pread, but I can't seem to get it to work. Are there any examples for how to use it. Because it doesn't work in the way that I thought it would.
-Kit
I don't remember if in "Multi propeller board" thread is some code about this, but if not,· I'll try to post it early.
I can tell you now, what I did to get the 400Kbytes/sec in read.
1-I used sdfat.pread
2-I read everytime blocks of 2048 bytes each.
3-I used· four buffers, to put the data read from SD.
4-I tried to do nothing while read the SD...only one COG for that, in a repeat loop, and only looking for·a·status flag for the buffers, if they were read by the master COG.
5-I used a very fast SD card (150x)
6-I maintain all wires between SD and the propeller very short (Look at my multipropeller board pictures)
Regards.
Alberto.
Post your code so people can look at it. Generally it is easier for people to find your problem by looking at your code snippets. I personally just skip over threads where there is no code since it is nearly impossible to guess what is wrong.
