communicating an SX with the prop
I've been having trouble trying to communicate the prop as the master, and the SX as a slave... Bare with me since this the first time I've ever tried serial communication, and its been tough, to say the least.. and i don't own an oscilloscope.. I tried looking up code in SX/b for I2C slave code, which there really isn't.. Has anyone else had success communicating between these two chips? I need the SX to help out because the prop doesn't have enough I/O pins.. Any advice or a few good points of direction would be really great.
If you need more IO, I would suggest using a port expander. I've used·the PCF8574, which uses i2c protocol·and·has 8 ports. 8·of these devices can be addressed on the same bus.·You should also check out the PCA9554. Either can be placed on the same i2c bus as the propeller's program EEPROM.·I think there is a 16 port version.·
Paul Baker
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Phillips released their I2C license on October 1st, 2006
www.nxp.com/products/interface_control/i2c/licensing/
Beau Schwabe
IC Layout Engineer
