In Circuit Programming of BS2
I'm working on a project and I would like to be able to reprogram the BS2 while it is still on the PCB. The project itself will run off a 12v car battery. I came across the attached diagram on page 8 of the PDB schematics. It seems to indicate that for programming purposes, all I need to do is create a header on the PCB with the first 4 pins of the BS2 (SIN, SOUT, ATN, VSS) attached to it. So here are the questions:
1. Is this really all I need to do? I have read many posts that seem to indicate that the BS2 cannot directly receive RS232 levels on its input pins. Are these pins somehow special? Don't I need something like a MAX232 between the BS2 and the serial port of the PC? It just seems to be a bit too easy and that always worries me.
2. Is there any problem with connecting the ground of the serial port to the negative terminal of the battery? I assume these could be at different potentials and I'm thinking that would be a bad thing.
Your thoughts are appreciated.
Thanks.
Greg
Post Edited (Greg Norton) : 7/22/2007 2:45:46 AM GMT
Thanks.
Greg
The system grounds all have to be connected together. One of the best places to do that is at the negative terminal of the battery. In a car, that may not be convenient. You do the best you can, perhaps connect all your Stamp related grounds together at one point near the Stamp's power regulator and run a single ground wire from there to the battery terminal or a "big" ground near the fusebox or other connector panel.
