MSRS Problem - Can't access Control Panel
Wondering if anyone has enough experience with using MSRS with the Boe-Bot yet to help me with this?
I was able to successfully connect to my Boe-Bot via bluetooth, however I am attempting to access the control panel (localhost:50000/controlpanel) and I am being prompted for a login window requesting user id/password...
I have my internet options for internal communications turned down and insured that login is not required through InternetExplorer's Internet Options>Security window...I tried to login to the 'controlpanel' and use my Windows login/password combo to no avail...I verified that my Windows firewall has been disabled for bluetooth...
I believe this is somewhere in the BASICStamp2.csproj or BSServices code somewhere and just don't know where to look...
Any help would be appreciated!
Aaron Mitchell
I hear, I forget
I see, I remember
I do and I understand
-Confucious
Aaron Mitchell
I hear, I forget
I see, I remember
-Confucious
Did you find a solution or which internet parameter I have to modify
I try different way, without success
Thanks for your help
Patrick
Andy Lindsay
Education Department
Try loading v1.0 then c# from Microsoft.
Rob7
I try try to load again booth an advise
Patrick
But anywhay same login window localhost http 403, requesting user id/password...
Have you some info about this http 403 error and how de begin really with MSRS?
Thaks for your help
Patrick
I have not seen this error?
1.Can you post a pic of your screen? I would like to know where this error occur's.
In another words:localhost is when you are typing in the machine field, right?
2. You must completely remove MSRS 1.5 it sohuld not show up in the MSRS field when you select it !
Hope this helps,
Rob7
Post Edited (Rob7) : 9/21/2007 11:44:39 AM GMT
Same windows see doc. localhost window
(Some element are in french but easy to understand
I try also MSRS forum
Hope to receipt a solution soon, thanks a lot
Post Edited (EMILIOZX) : 9/22/2007 8:45:58 AM GMT
I found something interesting !
I finally recieved my Visual Basic.NET in the mail.
I also loaded all my updates, witch included internet explorer 7.
I loaded it and tried to run MSRS, and "it did not work"!
The window you posted came up for me also.
I looked at your post and it looks like you are running internet explorer 7.
I reloaded Internet explorer 6.
"MSRS now works for me." Again !!!
If you want to continue working with MicroSoft Robotics Studio, use internet explorer 6 or lower verizons.
My version is 6.02900.2180.
Any version of 6 should work.
Rob 7
Post Edited (Rob7) : 9/24/2007 10:18:58 PM GMT
