FT232R Self Powered Config
Has anybody used the FT232R in self powered configuration? It's described in Fig 12, p20 of the FT232R datasheet, v1.04. Any Gotcha's or quirks I need to be aware of?
Tom
Tom
I've worked with this chip enough to know not to take anything for granted (or to trust FTDI's datasheet and appnotes either, for that matter). Any data gleaned from experimentation should be given the most weight.
The 200k pullup forms a divider with the 10k base resistor so false reset shouldn't be a problem. Even so, I don't mind if a reset occurs. Right now every time I unplug power from my custom board and plug power back in with the usb cable connected, I get a latchup in an i2c bus chip that I think is caused by power flowing through a substrate diode on the propeller. I measure almost 1 volt on Vdd. I suspect the demo board would do the same if I tried with the same ic but it's surface mount so I can't try it easily (my circuit is essentially the same as used on the Demo board).
Although I have plenty of excess capacity in my power supply I'm curious if it goes into USB Suspend mode when reset# is pulled low, thereby lowering current draw. Do you happen to know?
Tom
Tom
