BS2 versus BS2e
I am working with the bs2 and discovered with time that my eprom is now full, so I went and bought a BS2e. What do I need to know to use the bs2e with my program that I was using with my bs2?
Thank-You Toby
Thank-You Toby
Also, be sure to change any timing values, like Baud mode values and timing values in PULSOUT commands, etc. since these vary from Stamp model to Stamp model. The PBasic manual has the proper values for each model under the statement/command involved. I think the BS2e runs at the same speed as the BS2, so these values may not have to change. Check the manual.
