Part 2 of robot in progress
I have another video if anyone wants to check out my progress
www.youtube.com/watch?v=mhkLgu3wBlc
Still need to modify the program and i have a new chassis in mind to allow for a bigger battery
My web site -- > www.floodhound.com <-- take a look if you like
Post Edited (floodhound) : 7/21/2007 6:11:26 AM GMT
What's the purpose of the up-motion of the PING?
Does it check for obstacles also when it's moving fwd?
I am working towards this idea of guarding my home and making rounds at night. I just put on a 110db siren and man this thing is loud, so if i can detect obstacles then i should be able to detect a person breaking into my home. Testing is slow because i am looking for a better platform to put all the electronics and gadgets i have made inside.
This idea came to me when my home was broken into during my trip away for my birthday.
If you did a mapping system I would suggest a more "realistic" and less "gps/beacon" system. I know the army is looking into detecting position based on the surroundings and not what a satellite says.
it looks like because of the speed and weight of your bot it coasts for 6-8" which is causing it hit objects. can you brake the motors or can you only turn them off.
my plans for a sentry bot was to have the bot roam at random or a path. along the way I was going to have it sit for 20-30 min. go into a low power mode and monitor a PIR sensor. (detecting movement) if something moved it would say "enter code is 10 seconds" or something to that effect, and then count down to the siren sounding. voice commands would only add to coolness.
with an effective mapping it would be cool to have the bot make a round or 2 and then go back to a charging station until the next shift.
I have plans to add tilt to my PING as I have coffee table issues also.
it will be interesting to see what direction you take it.
P.S. I like your desktop app. I use it all the time now!
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
Yes i can break the motors by bursting them in reverse. I am testing it to see how effective it is going to be. I do have a function that says if distance is < 100 then stop but some times i still get into trouble. For the record i am using a IR sensor and perhaps this might be part of the problem.
Your idea is close to mine about seeing a movement and countdown. Except i got a mini car alarm siren that i can sound if need be. It wakes you up let me tell you and for being less than 3 inches i can fit it in soon.
Thanks for using my program. I will have to put my "speech activated" program up on my site soon so that you can give it a try as well.
Never give up when things go wrong.
my web site if you are interested robosapienv2-4mem8.page.tl
