problem w/ new spin stamp
ratronic
I am hooking up a new spin stamp and I can't get any of the I/O lines to go high and low. They just stay low all
the time. I have connected both vss pins together on the chip and am using a new fresh 9v rechargeable on the
vin pin. I get the regulated 5v volts out the vdd pin. It will accept a program either to ram or eeprom as the lights blink on the prop plug blink and I can see the data in and out w/ a scope. The reset line line also has a momentary pulse on it at start of programming. Am I missing something maybe? Attached is the program I am testing with and have also tryed the heartbeat program. Also does anybody know if a spin stamp w/ the prop clip attached will still have room to plug to plug into a bread board or does the prop clip take to much room for the pins on spinstamp to plug onto a breadboard? I am using a prop plug w/ 4 pin header soldered to chip and verified
it is plugged in the right way.·Any sugestions???··Thanks Dave
Dave Ratcliff· N6YEE
D RatFix it if ain't broke·
spin
201B
Paul Baker
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ D Rat
