Stamp and Pink Power supply
I'm trying to find a suitable power supply for a pink, OEM BS2, RF module and a few led's.
The PINK draws 5V @500mA
The BS2-IC consumes 8 mA (guessing the oem BS2 is 24mA)
the RF module is 10 mA
and about 30 mA for the LED's
so round that to 610 +/-
I'd like to use the a 7805 voltage regulator because I have a some on hand and it's a quick and easy circuit.
I know I'll need to have a heat sink on the 7805 and I can draw about 1A from. but I just want to make sure I'm not forgetting something. Is this circuit going to be too noisy for this application? I don't want to shorten the life of my PINK because of a cheap power supply.
does anyone have a better circuit for this application?
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
This is the best trade off I could come up with given I also needed 12VDC regulator also. Both are fed from their own halfwave rectifier at 14VDC ungregulated. With a lower voltage you could use a small heatsink I'm sure.
Since the bs2 is over kill for this project perhaps I'll add temperature controlled to the fan.
As for the BASIC Stamp 2, running it takes ~3mA, although the OEM’s regulator may lose a little more than the Module version. ·Still, 24mA or even 8 seems high.· I almost thing the RFID Reader was higher than what you listed. ·I would have to check it myself.· Take care.
Thanks for the input.
added:
that what's in red
Post Edited (Dgswaner) : 7/22/2007 12:04:54 PM GMT
