Fast-acting temperature sensor?
Phil Pilgrim (PhiPi)
I have a friend who's into paragliding. He's expressed an interest in recording temperature vs. altitude during his flights. (He says it will give him information about the stability of the airmass.) The catch is that his altitude can change as fast as 750fpm in a good thermal. With the average adiabatic cooling rate being around 5.5 deg. F/1000 ft., I doubt that the usual suspects among temperature sensor chips (e.g. DS1620) can keep up. Can anyone recommend a temperature sensor with low thermal mass that can track the anticipated rate of change?
BTW, I had occasion a couple days ago to examine a NASA dropsonde used by NWS for probing hurricanes. It had what looked like a teeny glass-enclosed diode, which I assume to be a temperature sensor. But I have no idea what the part number was...
Phil
Post Edited (Phil Pilgrim (PhiPi)) : 7/20/2007 3:58:49 AM GMT
Phil
"...It had what looked like a teeny glass-enclosed diode..."
That's probably exactly what it was. The PN junction has a very reliable/predictable temperature response.
Read toward the bottom of this link:
http://www.capgo.com/Resources/Temperature/Semiconductor/Semi.html
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 7/20/2007 4:42:15 AM GMT
I will be doing this shortly to get accurate die temperatures of the Propeller, now I just have to figure out how to create a 100nA current source.
There is a Maxim App note on how to use an ESD diode for this purpose, while this isn't your application or help you find a part number, it should provide enough information for your application.
Paul Baker
Post Edited (Paul Baker (Parallax)) : 7/20/2007 4:52:32 AM GMT
This might do everything you need...
http://cache.national.com/ds/LM/LM84.pdf
Beau Schwabe
IC Layout Engineer
Paul Baker
http://cache.national.com/ds/LM/LM95231.pdf
http://cache.national.com/ds/LM/LM95235.pdf
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 7/20/2007 5:17:49 AM GMT
Wow, I've been tag-teamed! Thanks so much for the rapid, informative responses! Yep, this has got to be the way to go. I can envision a remote SOT (or smaller) transistor-as-diode, hanging in the air, soldered to two thin strips of copper foil for maximum thermal response to the ambient. And the National parts make it drop-dead easy to interface. This is gonna work!
Thanks again!
Phil
Beau, that LM84 is interesting -- It looks like a good bet for monitoring the die temperature of the Prop that Paul putting through the paces in the new environmental chamber!
Tracy Allen
www.emesystems.com
I assume by "stranded wire" you mean thermocouple wire like this? How do you weld the two strands?
Phil
"Beau, that LM84 is interesting -- It looks like a good bet for monitoring the die temperature of the Prop that Paul putting through the paces in the new environmental chamber!"
Yeah, I "think" that if you use isolated power supplies, you can use the reverse biased diode(s) available on any of the IO pads. This way you could monitor virtually any chip.
Beau Schwabe
IC Layout Engineer
I've never tried DIY welding on the small wire. I've heard it is kind of tricky, but not hard after all the parameters are adjusted.
Tracy Allen
www.emesystems.com
Paul Baker
"...They seem to indicate the need for a dedicated diode connected transistor as done on Pentium chips..."
I believe this will be more of a calibration issue than anything else... once the parameters are defined, then the number returned would represent the correct temperature.
Beau Schwabe
IC Layout Engineer
Paul Baker
I think that is why Beau specified that the LM84 (and its support processor) needs to be run off of an isolated power supply. There is no connection between the grounds nor between the Vdd's of its power supply and the one running the Propeller under test. From the perspective of the the LM84, it is like it is hooked up to an isolated 1N4148, but it is one of the substrate diodes on the Propeller. The propeller is running on its own power supply, and it does not know that one of its substrate diodes has been taken over. That test pin is not used for anything else, and it seems it could be configured as input or output, it doesn't matter, but Beau would have a better advice about that.
Tracy Allen
www.emesystems.com
Paul Baker
In joining thermocouple wire into thermocouples, I've seen a procedure where the wires are tightly twisted over a few millimeters, and then the very tip momentarily brought vertically into a very hot oxy/acetylene flame, fusing the metals together.
It creates a tiny fused ball at the end and appears to be quite robust,
Cheers,
Peter (pjv)
There is some discussion on the use groups about this kind of technique, but most of it pretty discouraging:
www.craftkb.com/Uwe/Forum.aspx/welding/4280/How-To-Tac-Weld-Thermocouple-Wire
Not at all systematic.
The oxy/acetylene technique sounds a lot easier, if you have the equipment.
Tracy Allen
www.emesystems.com
