SX and LV-MaxSonar-EZ1
I recently purchased a MaxBotix LV-MaxSonar-EZ1 to try out. I'm working on interfacing this sensor to an SX28 using the serial output and the PWM output. Has anyone else used this particular combination, and if so, would you have some code you wouldn't mind sharing? I'm getting some glitches in my readings, but I'm not sure if it's the sensor, my code, or the setup. Thanks.
Joe
Joe
