Do we need the eeprom/3.7v power supply
I am little bit confuse regarding the ram / eeprom memory.
My actual propeller developments don’t need to store any data on eeprom.
Is it really necessary to have it?
If I download the application only on ram, what happens if I cut the power end restart?
Another question :
The rest of the circuit use 3.7v power supply. Is it acceptable for Propeller ?
Another question :
3.7? Is this the nominal voltage from a battery like a LiPoly?
Graham
3.7 is a nominal power supply on pcb : LM2670 12 to 3.7v converter. Do i need another one for propeller?
sheers.
Graham
www.parallax.com/dl/docs/prod/prop/PropellerDSv0.3.pdf
page 25.
Personally I'd add another regulator, it only needs to be a small one.
Graham
Paul Baker
