Crystal question
Actually two questions. Is the 5 Mhz crystal included with the Propeller Education Kit a series or parallel resonant type? If I use a 4.00 Mhz external crystal what, if anything, do I need to change in the serial communications driver to get the proper baud rate, other than changing the frequency setting in the spin program?
Paul Baker
Paul Baker
You might also try the different xtal1/xtal2/xtal3 settings (see the chart in the manual). They change the load capacitance and are recommended for different crystal frequencies. You should be able to run the Propeller off a 32KHz crystal (not with the PLL) for low power applications like timekeeping.
Now in an upcoming lab they would just use one of those infrared receivers to record some signals from a TV remote and re-send them so I can build an automatic channel scroller for my girlfriend. One button for start, another for stop so she don't wear out the batteries in my remote, I'll be in heaven.
