Beyond basic info needed for Basic stamp LED board set up
Can anyone advise me as to what I need to purchase to make a very simple lights on and off LED board. I just want to be able to make and LED sign that i can progam the indevidual LEDS to go on and off at differant times.
I was thinking my shopping list should look some thing like this.
LEDs (x100)
Basic Stamp 2
Resistors (x?)
Bread board??
Help, I know nothing.
LEDs (x100)
Basic Stamp 2
Resistors (x?)
Bread board??
- Stephen
Would that be complicated for extreme novice with a kinda limited time frame?
Very greatful for your help.
- Stephen
Seeing that you want to generate letters, you need to think of the LED's as a MATRIX· (ROWS, COLUMNS).· Look for 5x7 LED projects for a quick example.·http://forums.parallax.com/showthread.php?p=661543 With a scanning matrix, you can greatly reduce the number interface pins needed, but regardless... you need a lot.
The only realistic way to do this is to offload the task to a chip designed to do it.· Like the MAX6592 http://datasheets.maxim-ic.com/en/ds/MAX6952.pdf·· More info: http
The datasheet shows that you need 140 LEDS just to make a 4 Digit 5x7 matrix display.· 5x7 = 35· * 4 = 140
Honestly, even 4 DIGITS at 5x7 using discreet LED's·is a lot of work and you only get 4 letters at a time.· Now, there are some $4.00 1" Matrix LED Displays which can save you some time.· I get part # 16786-OP from MPJA.COM.
I have also done this on a small scale with a part that seems to have dried up and faded away. The OSRAM PD2435. (http://catalog.osram-os.com/catalogue/catalogue.do;jsessionid=D79A58B42C7E0CE79F21F047311F8547?act=downloadFile&favOid=020000020000462d000100b6)
You can see by looking at what I've provided that this is a pretty big project.· Good Luck.
Post Edited (pwillard) : 7/18/2007 4:08:53 PM GMT
Stamp - fine but what board?
1) set LOW the Stamp Pin connected to the SPI Chip select pin.
2) SHIFTOUT DATAPIN, CLOCKPIN, MODE, [noparse][[/noparse]DATA\bytes]
3) set HIGH the stamp Pin connected to the SPI Chip select pin
Mode = MSBfirst or LSBfirst
Bytes = how many clock cycles in packet size
From the maxim datasheet:
The MAX6952 is written to using the following sequence:
1) Take CLK low.
2) Take CS low. This enables the internal 16-bit shift register.
3) Clock 16 bits of data into DIN, D15 first to D0 last, observing the setup and hold times. Bit D15 is low,indicating a write command.
4) Take CS high (while CLK is still high after clocking in the last data bit).
5) Take CLK low.
So, with the MAXIM chip, 140 LEDS, a BASIC STAMP2 and a breadboard you could probably get this working using some small amount of code and 3 dedicated SPI pins in the STAMP. A BS1 does not have this command. To do the matrix "right" you really want (4) 5x7 matrix LED assemblies.
Pete
Post Edited (pwillard) : 7/18/2007 4:16:14 PM GMT
- Rick
