Problems loading programs to BS2P40, USB 1.1 to blame?
Hello All,
I am programming my BS2P40 through the Professional Development Board and a USB cable. On shorter programs to test individual functions, every once in a while I get an error message:
"Hardware Communication Failure! Check serial cable and power supply."
Both check out fine, so I was just putting up with this issue. But on one of my larger programs (memory map shows addressed from 210-7F0) I will get this message every time from a random spot between 12% loaded to about 85%. I reloaded the USB driver but still no help. Could it be that the older computer I'm stuck using with USB 1.1 (and running WinBlows 2k) is the problem? I will be moving the project to the neighboring desk to run off my desktop for a test to see, just wanted to know if anyone else had a similar problem.
Chuck
Chuck
There are some settings affecting latency (how long it takes a packet of data to be forwarded through the USB adapter) that sometimes show up under WIN2K and other Windows OSs that might affect this.· I haven't experienced this, but I've heard of it.
Have you tried our troubleshooting FAQ on our USB Driver download page?
http://www.parallax.com/dl/docs/prod/ftdi/USBDriverTroubleshooting-V1.0.pdf
The nice thing to come out of this is that we used this to convince the boss to go with leased computers for the offices and the fairly new (at least compared to the antiquated P.O.S.'s we're using in the lab) desktop computers we are using now will become available for use in the lab.
Chuck
Post Edited (Chuck E.) : 7/18/2007 3:14:25 PM GMT
You guys ROCK!
Chuck
