Problem with USB driver
I am trying to install the USB driver that came on the CD with my BOE bot to a Windows 98 computer. I went to the software section, but when I select the USB driver the word "install" on the button turns gray meaning it is not an option. Can somebody please tell me what is/I am doing wrong. Thank you in advance.
D Faust
D Faust
"The DPINST file is linked to missing export ADVAP132.DLL: ConvertStringSecurityDescriptionToSecutityDescriptorW."
Does anybody know what I should do
P.S. I only see one driver on Parallax's site.
Also, are you saying that only certain versions of Win98 will work?
D Faust
(Although I would like to solve the problem through software)
D Faust
www.ftdichip.com/FTDrivers.htm
Doesn't the stamp's FTDI chip change serial to USB?
D Faust
The files are:
1) 906Releaseinfo.DOC 2) ftdibus.cat 3) Ftdibus.inf 4) ftdiport.cat 5) Ftdiport.inf 6) FTDIUNIN.exe 7) Ftdiunin.ini 8) ftsermoui.cat 9) Ftsermou.inf
Usually an install wizard pops up when things need to be installed, but it did not. How can I install these files without the wizard/access the wizard to install this?
Thank you in advance for any suggestions, I'm not really a computer expert.
D Faust
______________________________________________________________________________________________
Update:
It works!!!!!· I did exactly as Chris said and I·got the USB to act as a COM port.··I thank you both very much!
D Faust
Post Edited (D Faust) : 7/19/2007 1:59:46 PM GMT
Can I use USB-to-Serial cable for my Basic Stamp 2 ?
My laptop doesn't have a serial port only USB.
Thank you.
wuzlum
LOOKDOWN This_Thread, [noparse][[/noparse]Your_?, My_?, Cool_Thing], looknum LOOKUP looknum, [noparse][[/noparse]1, 2, 3], subnum ON subnum GOTO your?, my?, cool your?: DEBUG "Hope This Helps!" END my?: DEBUG "Thank You For Your Time" END cool: DEBUG "WOW!!" END
And the BS2 implements 12 volt RS-232 to 5 volt BS2 signal conversion already on the 'programming port' DB-9, so you don't need to worry about that aspect. If you want to use SEROUT/SERIN to a PC on other BS2 pins, then you will need an adaptor with a MAX232 or equivalent to convert the BS2 5-volt signal to an RS-232 +- 10 volt signal. And another DB-9 connector.
Sorry if I wasn't clear in expressing my problem..
The scenario is this:
Before, I use Serial Port to program and debug BS-2.
But now, my new laptop computer comes with No Serial Port.
This new laptop only have USB Ports.
Now I'm not sure if I can use a USB-to-Serial cable for programming BS-2.
I'm only using the BS-2 chip alone, no other experimental boards.
Post Edited (wuzlum) : 8/10/2007 3:05:48 AM GMT
We carry a USB to serial adapter that can be used in place of a Serial Cable. Please see the link below. Take care.
http://www.parallax.com/detail.asp?product_id=28031
LOOKDOWN ThisThread, [noparse][[/noparse]Your_?, My_?, Cool_Thing], looknum LOOKUP looknum, [noparse][[/noparse]1, 2, 3], subnum ON subnum GOTO Hope_this_helps, Thanks!, WOW!! END
Post Edited (D Faust) : 8/10/2007 12:17:02 PM GMT
Thank you guys for all your help.
