How to scale numeric ranges
Sorry if this is clearly discussed somewhere else but I am having a little trouble getting my mind around the process of converting one range of numbers to another scale. For example: I want to drive a servo (300-1500) with the output of a Ping! module and have 1-50 from the ping map to the 300-1500 scale needed for the servo. I saw the explanation of this sort of operation in the Smart Sensors documentation but am still having trouble putting it into practice. If anyone can spare a couple seconds to try and maybe give an alternate perspective on how this is done I would be very grateful.
Thanks again!
Thanks again!
If you have the PING value in the variable "p" and you want the servo value in the variable "s", you do:
s = (p * 24) + 300
OS-X: because making Unix user-friendly was easier than debugging Windows
links:
My band's website
Our album on the iTunes Music Store
