sx overheating trouble ??
I've created several circuits using the sx-48/52 proto pcb recently, clocked w/ the 50mhz resonator. I noticed an extremely hot sx chip by accident (ouch !!)... tried the code on a second proto pcb w/ out any circuitry attached to the ports. still very hot... reduced the clock to 4mhz & all is cool !!! is this a common prob ?? I added heatsinks to the processor for now, but had anticipated moving forward w/ all future projects @ 50mhz.. am I missing something, or can the speed alone cause heat issues ??
thanks,
jesse_in_venice
thanks,
jesse_in_venice
thx,
jesse_in_venice
-Warm: just that. warm when you touch it
-Hot: hold your finger on it and after a second or two, uncomfortable. Almost pain but not. No burns. No ouch.
-Very Hot: unable to hold your finger on it for more than two seconds. Pain. Maybe burns. Ouch.
-Really Hot: instant burns, power transistors etc. You can smell them burn fingerprint oil etc.
My proto board, running @ 50, turning two LEDs on and off as fast as it could (SXB), got Hot. It was just uncomfortable.
Not a good test as my finger dwarfs the tiny chip and probably acted as a heat sink.
Did yours crash by itself? I did notice twice when I touched mine, it stopped running. I'm sure I loaded down the oscillator or something. I was pressing pretty hard.
Just thought I'd pass it along,
HTH, Chris
I'm not scared of your robot. I'm covered by Old Glory (youtube)
I have two blank 48 proto boards. One was more heat tolerant than the other, but both would fail running @ 50. One took about 15 minutes to fail and the other took over a half hour. So out came the hair dryer and I stress tested them pretty good. I didn't have any freeze spray so I couldn't get them to snap back on, but it was pretty clear. Under the gun, they would fail in about 30 seconds. If you have never used a hair dryer or worst a heat gun on circuit boards.... DON'T. It's something I used to do in my 'tech days' and it can be very hard on parts and boards.
Now for the good news. Running the same boards @ 20MHz, I got no failures. I did get it to fail with extreme heat but it was way, way above normal operating temps. Above Very Hot. Much more and I would have melted the plastic parts. Hey, it's only a $10 part and in the name of science. Back at normal temps and everything is running fine.
Some thing's happening in there. The board can run much hotter at 20MHz without failing. I don't think that's unusual. What it does mean, is that we'll have to run them at 20MHz. If you have to run at 50MHz, it will mean more work. i.e. fans, heat sink, whatever.
Note: I ran all my tests with OSCHS2
HTH, Chris
I can run three watts with this method, the putty stays put as well under what must be very high heat under that led.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
I've been Googling around to see what the story is with super glue. Some say no, others say ok but try to get some heat sink metal flush with the chip. I'm not sure what that means. I'll try to get my hands on some of the Artic glue stuff. All my stuff can run at 20MHz (or slower) with no problem, so it's no big thing. BUT I think it was Gunther that said in his book: "You have a Porsche there, why are you driving around in first gear?"
For my stuff, I have plenty of power available. However, I'm in a hot climate, so heat is bad.
I saw in the Prop forum that they (Parallax) have a new chamber. Maybe we can talk them into testing the boards.
Chris
I've used J-B Weld, a metal-filled epoxy, to attach a small finned heatsink to the SX. It worked great.
Another app involved an extrusion, where it was possible to slide a piece of sheet aluminum in above the SX. A small piece of Bergquist Gap-Pad squeezed between the SX and aluminum conducted the heat away without using any other heatsink compounds.
I have some J-B weld. I think that would be much better than super glue.
Chris
thanks for all the input,
jesse_in_venice
(I attached a couple snapsohts of the guilty pcb's)
