Poor Man's SD Card Socket
Hmmm, not sure if it's worth posting, but at least it should be good for a laugh... :-D
Behold my Poor Man's SD Card Socket made from Paper Clips.
Now, isn't it amazing what one can do with these things... ...henceforward call me McGuyver!
The Clips are kept apart by the wire bridges·only, no glue was applied.
And it works perfectly, I just watched Bagger's stunning Video Demo.
Cheers.
Clemens
Cheers.
Clemens
now to build it into a module on some perfboard
Parallax Forums - If you're ready to learn, we're ready to help.
I think that I read somewhere (Book of Odds?) that the chances of a paperclip actually being used to clip paper are only 1 in 2. HALF are being repurposed.
Good !!
Just only let me to comment something about this....
Each time, you'll have data transfers, like in this case from SD to propeller, try to maintain wires as short as possible, also, try to put a .1uF capacitor ...near the SD power pin. You'll have better results (or more speed available).
Regards.
Alberto.
I've never seen paper clips with those ends. I see one is clipped off else possibly wouldn't insert into the solderless breadboard.
Not the highest conductivity, but for low current apps beyond adequate.
What keeps them from shorting any? Or is the SD module not hot-pluggable?
Must have made some sort of jig for the bends. I'd not be able to make two the same otherwise.
Interesting on 'repurposing'. Hadn't run across that info. The pics provide good example on 'how to'.
Harley Shanko
h.a.s. designn
Graham
With your attitude you could re-purpose the Propeller into goodness knows what, maybe the QFP pack could have the legs bent down and it could be turned into an ant prison.
*Peter*
Clemens is a bit like our OZZIE bushtucker man "LES".. good for a laugh..but very hands on..
Well executed... Clemens.
Cheers from Australia
Ronald Nollet
@ Alberto
Thanks, I'll make these Changes.
@ Graham
Actually I did this once, but the ungrateful furballs preferred to learn to play the piano. It's more "mouselike" they say... ;-)
Cheers,
Clemens
E3 = Thought
http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! The average PC while browsing the internet typically uses less than 30% of it's potential, why not donate a portion of the rest for cancer resaerch?
My Blog: Prog | Electro | Mech
I would love to change the world, but they won't give me the source code
People say that if you play Microsoft CD's backwards, you hear satanic things, but that's nothing, because if you play them forwards, they install Windows.
I spent a minute looking at my own code by accident. I was thinking "What the heck is this guy doing?"
Post Edited (Fred Hawkins) : 8/18/2007 5:28:11 PM GMT
(Man, I'm using brackets a lot, don't I.) :-D
Btw, that administrator is responsible for me owning a propeller, he showed me the propstick and I fell in love right away... But being a graphic-designer, I probably spend too much time optimizing my breadboard setup, where I should learn some spin and assembler.
Some of us Germans are funny people, like deSilva already pointed out. I totally agree with him, that there should be no other chip on my setup except for the propeller. - and I might add, you should avoid soldering whereever you can. Welcome to the fine art of dogma-prototyping.
I have been looking online, and I am having a hard time finding it.
Or have a look at the many Propeller drivers for it..
http://obex.parallax.com/objects/92/
Paul Baker
Post Edited (Paul Baker (Parallax)) : 8/28/2007 7:38:34 PM GMT
That said these are still online:
http://www.sandisk.com/Oem/Default.aspx?CatID=1416
http://www.sandisk.com/Oem/ApplicationNotes/
There's more at Sandisk who have seem to have a rat's nest.
Sandisk did send me on to http://www.sdcard.org/home/
physical specs (under the About SD Memory Card menu link)
http://www.sdcard.org/about/memory_card/pls/Simplified_Physical_Layer_Spec.pdf
About halfway down their menu is "About Host Controller" which has these expurgiated spec (probably hides the drm aspects)
http://www.sdcard.org/about/host_controller/simple_spec/Simplified_SD_Host_Controller_Spec.pdf (this link skips an intro page and an Eula)
This pdf download was slow and may be incomplete. On my first try, Adobe reader claimed 525K of 578K.·On the third try, it downloaded completely.
Post Edited (Fred Hawkins) : 8/28/2007 8:40:15 PM GMT
Paul Baker
Other good refereneces:
http://www.maxim-ic.com/appnotes.cfm/an_pk/4068 This one has a decent description of crc calculation.
Texas Instruments has some very nice step by step procedures for all of the major things you need to do. They are inside the docs for their sd card modules that are in their daVinci chips. Or for their bricklike (18mm square chips with 288 bumps on the bottom) sd card interface chips -- those are only available to oems apparently and are used to manage the card slots on laptops etc.
Here's one doc: http://focus.ti.com/general/docs/techdocsabstract.tsp?abstractName=sprue30b
Just use their search function to find others using this argument: "SD Card controller"
The times had been much simpler then, and there is leaner documentation
Excellent job on your SD Card socket!!· This coming weekend I may have to try this out, but I will have to use the funny triangular paper clips we have here in Hong Kong!
Timothy D. Swieter
tdswieter.com
One little spark of imagination is all it takes for an idea to explode
-Mike
······ I'll try everything once [noparse]:)[/noparse]
http://uanr.com/sdfloppy/
regards peter
Great link! I have everything i need to create that SD card reader already, i'm excited...
-Mike
Adapters (microSD to miniSD and to SD) are now cheaply available in pairs so you can hardwire one of the sockets. And using a microSD, you can also get the USB to microSD adapter as well - more expensive, but very common.
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
· Search the Propeller forums (via Google)
