USB TO SERIAL ADAPTER(need help)
I have a BasicStamp 2 Homework board rev d and I'm trying to get the basic stamp editor 2.3 identify it but i have a Serial to USB adapter. When i go into run and identify it does not identify my board! Can somone help me?!
What brand is the USB to Serial Adapter? Are you able to measure the voltage going into the board?
Make sure the USB to Serial cable's driver is installed. If it isn't the system will most likely not recognize the device.
While in DEVICE MANAGER, scroll down to PORTS (COM & LPT), if it isn't already open, click the + symbol and open the tree view. This area lists all of your available ports. Your USB to Serial cable should be listed and a port assigned to it. If it is not then reinstall the cable's driver(s) by rerunning the software and check again. If it is there take note of the port number.
Make certain your battery is attached properly to the Homework Board. Now perform your IDENTIFY.
I hope this helps.
Post Edited (Chase) : 7/15/2007 1:07:33 PM GMT
Try this ...
http://www.dynexproducts.com/t-drivers.aspx
Thank you!
Let me install it and try to identify again.
·· In the future please do not follow your posts with·posts like the above.· Forum Members will post when they read the message and have something to offer.· Also, please do not duplicate these requests in Private Message.· Keep your replies in the forum where everyone can benefit from answers given.· If somsone suggests a course of action, a reply of "nothing" doesn't allow us to help you as it doesn't provide any useful information as to what happened.· Please try to be clear and provide details in your replies so we can help.
