SPI and I2C mixing
I am attempting to design a data logger with a BS2, DS1302 clock chip, and EEProm 24LC32A.· I think that the 24LC32A requires I2C bus use, and the DS1302 requires SPI bus use.· Is this right?· May I mix them in one set of code?
The only sample code I could find for the 24LC32A was an I2C demo, so perhaps I have the wrong conclusion.
- Stephen
I realize you are working on a BS/2, but I recently posted code in the Completed Projects part of the forum then uses SPI and I2C with an SX-28 Chip using the SX-B BASIC compiler.
http://forums.parallax.com/showthread.php?p=659734
I'm using the smaller 24LC16B chip, so most of the stuff should be the same.
Hope this helps,
Dan
I'm not scared of your robot. I'm covered by Old Glory (youtube)
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
- Rick
Thanks for the help.· I'm off and reading to see if I can understand all this stuff.· It took me a while to even recognize the difference between the SPI and I2c approaches.
Craig.
- Rick
