Prop 2 Packaging; Prop 1 drop-in DIP in the cards?
I apologize if this has been asked somewhere before, but the most recent Prop 2 feature list on the "Which would you want more of..." post currently reads...
Is there an desire/hope/commitment from Parallax to produce a version of the prop2 in a DIP package which will be a drop-in replacement for the Prop 1? I haven't been following all the details closely enough to know if there are hardware features which preclude this possibility, but it seems to me that if it were possible there would be a large number of existing customers who would buy DIP prop 2's to upgrade their existing prop 1 boards.
As for me, I am the middle of a commercial Prop 1 design and I had been intending to use the surface mount version, but if a compatible prop 2 dip is planned then I will switch to a socketed DIP so that the units will be field upgradable to the prop 2 whenever it becomes available.
Packaging QFP preferred pg19/19Jun07/6:03p
QFN ?
LQFP ?
BGA ?
thru-hole DIP NO ?
Paul Baker
Post Edited (Paul Baker (Parallax)) : 7/12/2007 4:54:16 PM GMT
Understood. Thanks for the reply! I'll stick with the surface mount Prop 1 then.
I am new and have not read all the posts on new propeller. Is ther any chance of having PGA 13x13 or PLCC84 packages options ? Such package allow home made prototipe boards and soldering very inexpensive (10 mils route, double layer, no smd, pass-through components becomes vias)
regards
Found it using the search string 'Brian L. Propeller II packaging' on http://search.parallax.com
Don't visit my new website...
