Problems with Propeller education Kit
I wired up the breadboards as shown in the instructions. Before inserting any chips I was reading 4.6 volts on the rails. I know this is not good. I tested the LM2937 regulator out of the circuit and found the same voltage. I replaced the LM2937 and got 3.3 volts on the rails. After inserting the chips all was well. Pressing F7 found the chip, and I was able to load the first test pogram and save it to the EEPROM. To check out the EEPROM I disconnected the battery and the Propeller clip, put the battery back on and all was well for a few minutes, then the LED suddenly stopped flashing. After that I was unable to do anything else. Pressing F7 now tells me "no propeller chip was found". Using an oscillosope on Pin 40 of the propeller chip I see what appears to be the probe from the propeller clip, but I never see anything on the reset line or the output of the propeller chip.
First there's a bad voltage regulator, then either the propeller chip or the propeller clip simply failed while running. I also tried a different crystal, I don't have any 5 mhz crystals but I tried an 8 mhz, hoping to see some sort of response, but nothing happened. I am NOT happy! Other than tossing the whole thing in the trash and writing $80 off to experience, do you have any other ideas?
Tom Wyckoff
Tom Wyckoff
Paul Baker
With regards to the Propeller. I have a 40 pin DIP and received two voltage regulators with it. One to drop the input voltage to 5 volts, and another to drop it to 3.3. I found that If I used both the voltage regulators, I ended up with 2.7 volts and the Prop would not run. I removed the 5volt regulator and just ran the 3.3 volt, and when all hooked up I have a steady 3.3 volts on the rails and the Prop runs great. I am unsure why the 5volt regulator was needed? I am certainly no expert on this, so best to get help from the Parallax guys, but just my 2cents.
The 5v is used in some of the later lessons, I think.
Just using the single regulator would probably chew up your battery as surplus heat.
Post a picture, maybe we can spot something. Like taking your b+ from the power on led circuit.
There are two good reasons for using both a 5 volt and a 3.3 volt regulator. To sum up what was previously stated, going from 9 volts to 3.3v directly with these type regulators is going to generate a lot of heat and give poor regulation, and, you will need 5 volts for many TTL applications. Many LCD displays must have a good 5 volt supply. Many sensors must use 5 volts, etc. I suspect this is why Parallax uses them in the PE kit. Personally, I use a 5 cell NiCad pack and don't use the 5 volt regulator. They are cheap and can be recharged.
Richard
I am no engineer, so my wiring may be incorrect in some way.
It really depends how much current you're drawing through the regulator. Even at 100mA you're only wasting maybe half a watt of power, which IMHO the piece of metal on the back should be able to dissipate just fine. Put a motor or something on there, though, and suddenly you have your own miniature space heater.
Another option is a switching regulator, like this.
I should have noted that heat generation would only be a problem if operating at rated current. I could be wrong, but this type of regulator is met to be heat sinked if operating at max specs. Dropping from 9 to 3.3 volts at 250ma (not sure of the rating of the PE supplied regulators) would require dissipating about 1 1/2 watts. Don't think these regulators will handle that without a heat sink (I could certainly be wrong though). If you do any kind of apps using sensors you are going to need a 5 volt source in addition to the 3.3 volts. As I said, you can use a 5 volt regulator or a 5 cell NiCd/NiMh.
Richard
Ouch - the 3.3V 1 Amp Dimension Engineering switching regulator you recommended costs $15 each.
Have a look at Texas Instrument's PTH04000W, a 0.9V-3.6V adjustable 3 Amp switching module (3.3V or 5V input), the product page is here.
The PTH04000W costs around $4.50 ea. in large quantity and $6.56 ea. in unit qty (digikey P/N 296-20392-ND).
These regulators have what is called 'Auto-Track', a feature that allows multiple modules to be powered up/down synchronously even if they are handling different voltages. Auto-Track may be useful in motor applications where more than one module may be in-use. These modules come in either surface mount or through-hole 6 pin DIP MOD form-factor. Each is about 19.0mm X 12.5mm X 8.5mm. A 47uF input cap is required, a 47uF output cap is optional.
I'm still searching for an optimal 3.3V 1A-3A switcher module for propeller - any other suggestions are most welcome.
David
If package is not critical - take a look at this little beauty ... its a DC/DC converter but just look at the specs !
They call it a 'complete switch mode power supply' ...tasty bit of kit.
www.linear.com/ad/micromodule.jsp
Also attached pdf..
Quattro
'Necessity is the mother of invention'
Post Edited (QuattroRS4) : 7/13/2007 4:03:10 AM GMT
The most common cause of the symptoms you describe is one or more broken wires. Typically, a wire gets nicked as the sheath is removed when cutting it for tight wiring. Then, bending it gets it ready to break, and it breaks when it gets inserted into the socket. Sometimes, the remaining sheath is still holding it in place so that it doesn't look broken. After a few minutes of operation, the tenuous connection drifts apart.
Broken leads are not out of the question either. For example, there have been two cases with 4.6 V measured at the LM2937 output that were because one of the leads on the regulator output caps were broken during the bend and socket phase. (I have also managed to inadvertently produce this symptom by inserting a capacitor lead into the wrong socket.)
Sometimes a quick continuity check with a meter will unearth one or more broken wires. In other cases, continuity will come and go as the probes are pressed against the sockets since the shape of the board bends slightly. Especially if I examine a wire or two, and they show evidence of having been partially cut when the sheath was removed from an end during tight wiring, I usually remove and examine each wire looking for breaks and replace any questionable wires.
Andy
Andy Lindsay
Education Department
Post Edited (Andy Lindsay (Parallax)) : 7/13/2007 11:09:01 AM GMT
Thanks for bringing up the Linear Tech LTM46XX... parts, I agree, they're impressive, especially for high current apps. I've looked at these parts before but bounced off them initially due to the difficulty handling the package form-factor in prototype. Even a carrier board would be difficult. 1000's qty. price in a Linear press release is around $12 USD ea.; a quick search shows these modules to run around $30 in unit qty. and $18 in 100's. But they're still interesting parts nontheless given the power and size. I need to look further at them though to see if there is a way to synch the start-up/shut-down like the TI module I mentioned previously. This is important in apps that need current to more than one peripheral each drawing more current than one switcher module can provide; to prevent burning stuff out when you power off/on, "distributed/scaleable power" if you will. Last but not least, I need to look more at the transient performance of these Linear modules. I suspect that with in-module magnetics and such a small package there are going to be compromises in energy storage - hence transient load performance. In-summary; given the hard to prototype form-factor and high unit price, I don't think I will put these parts at the top of my list for 1A-3A switcher module options.
I think the thread about these switcher modules is diverging from Tom's original question, perhaps we should start a new Post about this. My apologies Tom.
Best Regards,
David
Post Edited (Drone) : 7/13/2007 3:45:48 PM GMT
I replaced most of the wires on the breadboard, found 3.3 volts on all the rails and on the chip where needed. Still no-go. Then I installed a new propeller chip and it loaded the program from the eeprom and started running. Yay! I have not connected the propeller CLIP yet, see my previous post for a question about that. The last thing I want to do is smoke another $13 chip.
I did notice that the ground side of the capacitor on the output of the 3.3 volt regulator takes a somewhat circuitious route to ground, passing through three jumpers. Maybe a shorter path couls be found for something this critical?
Anyway, if someone could answer the question in my last post regarding the voltage I found on the data input lead of the propeller CLIP I can proceed.
To repeat, I found around 3 volts at the INPUT pin of the propeller CLIP, this is connected to an output on the propeller chip and seems unusual, unless that output is an open collector and pulls the CLIP input low to communicate?
This is not a technical answer, just an observation. Which is, when I have my board powered down but still connected to my pc through the plug, the board's power on
led lights about 50% of its usual battery powered state. So, having a plus voltage there does seem to make sense.
As to your cap question -- check out my alternative layout (at least as far as the power is concerned). It is in the Setting and Testing discussion thread:
http://forums.parallax.com/forums/default.aspx?f=25&p=2&m=147808
Fred
Thanks to all for the assistance here.
Don
The LM2940(5V) is a low dropout regulator only requiring 1 vbe.
http://cache.national.com/ds/LM/LM2940.pdf
Beau Schwabe
IC Layout Engineer
