An SPI question.
Why do they tie the SI and SO together, and the serin & serout commands use the same ports, instead of connecting seperate ports to SI & SO and using serin with the SO port and serout with the SI port numbers? Will both ways work with an SPI ram IC?
- Stephen
Note that tying the serial input and output pins together when the device doesn't support it can damage the device or the Stamp or both.
