Broadcasting video with sound — Parallax Forums
LewisDLewisD Posts: 29
edited 2007-07-11 18:04 in Propeller 1
Hi All,
I am setting up TV broadcasting with the prop to send telemetry back from a robot and
I was wondering if anyone has also sent Mono or Stereo sound as well as Video?
Would it take another cog?
How would it be mixed with the video?
I am planing on doing something like this ...
www.technotoad.com/how-to-build-your-own-rf-modulator-for-your-tv.php
(I would put my antenna on the Modulators TV out.)
But I was hopping for a more elegant solution.
LewisD
Post Edited (LewisD) : 7/11/2007 9:48:19 AM GMT
  • ciphernetciphernet Posts: 24
    edited 2007-07-11 16:03
    Since audio has it´s own carrier frq. in a Pal/NTSC television RF transmission, I can´t see how you can mix·video and audio·unless you use an external modulator circuit or generate an extra audio carrier frq. for the modulation of the sound and then mix the two outputs.
    Jan
    ·Give me some slack, please.. I have programmed SX controllers for five years but the prop just blows my mind :-)
    edited 2007-07-11 16:14
    If you look at the documentation for the video generator, limited as it may be, you'll see that the PLLA of one of the other cogs is used as the subcarrier frequency source for the audio subcarrier. This subcarrier can be modulated by that cog to provide the audio for the TV signal.
  • KaioKaio Posts: 281
    edited 2007-07-11 16:25
    LewisD,
    I don't have seen an example for this in the forum. But I know from the documentation of the TV driver that you have to use a separate Cog to provide the modulated audio signal. In the TV driver you have to set the parameter tv_auralcog appropriate to the Cogid. You don't need extra hardware, the Propeller will do the mix.
    Thomas
  • deSilvadeSilva Posts: 2,967
    Alas, also Andre LaMothe is very tacid about this feature in his elsewhere instructive and comprehensive book...
