High speed counter
Help me·please.
1. What is the Maximum·speed·if I·use the BS2 as a pulse counter?
2.·I wonder if I can use the·BS2 to·be programmed as a high speed·counter.
The functions of the counter would be just like most of the high speed counters.·When the incoming pulse reached the preset number then an output pulse would be generated. The reset number can be changed by two push buttons. One is for increase and the other is for decrease.
Thank you very much
Hai··
Help me·please.
Thank you very much
Hai··
The max counting speed depends largely on how much other code the Stamp has to process while not missing any incoming pulses.
In a similar application, I counted fairly reliably at 30 to 60 pulses per second.
For true high-speed counting, an external counter will give the processor some extra time to do other things, then come back and check the counter.
If you can give us some more details, I'm sure several other suggestions will emerge.
Cheers,
Tom Sisk
http://www.siskconsult.com
I need to set up a device that could send out a pulse to trigger the camera to take a registered photo on the high speed moving paper web.
I know a high speed counter could do the job. Use the cue mark on paper as a reset and count the encoder pulse to trigger the camera.
But I want something better and easier for the operators to set up the camera. 1. Automatically measure and calculate the form length.
2. Use half of the form length as the initial preset to trigger the camera.
3. Use two push buttons to adjust the registration trigger, one is for increase and the other is for decrease.
Hai
The Propeller or SX could handle the job.
Bean.
Never argue with an idiot.· They'll drag you down to their level then beat you with experience.
www.hittconsulting.com
I agree with Bean; you will need more processing horsepower.
To get anything meaningful out of paper web photography, you need to be able to make some small, repeatable adjustments. On the 300 m/min and 1000 m/min machines I worked on, we often had to use high speed movie cameras and review the action frame by frame to see the problem area clearly.
Cheers
Tom Sisk
Thanks for the reply. I don't know anything about the Propeller and SX. Is the BS2-SX you were talking about or something else? I have to look in to the Propeller. Thank you very much.
Best regards
Hai
