Wheel encoder question.
ok. so.. im not sure where to start.
I have started putting together a new bot.. its got all kinds of goodys but what it doesnt have is any kind of wheel encoders. now its going to be a while before I need them but it got me to thinking about them, how they wrok, who makes good ones, and so on.. the base im using is http://www.lynxmotion.com/Category.aspx?CategoryID=57·with 12 volt motors. so what would· be good encoders for this base and please keep in mind that this bot will go outdoors although not in any real rough areas.
the next question/observation I have is this.. has anyone made a optical incoder? something like the optical mouse your using? just seems like a good idea.
thanks for you time
IC layout designer
Austin Texas
thanks for you time
IC layout designer
Austin Texas
http://www.geology.smu.edu/~dpa-www/robo/Encoder/pitt_html/encoders.html
Exactly what brand/model of motor are you using???
A while back I was experimenting with the possibililty of using the Propeller MOUSE.SPIN object with an old optomechanical ball mouse for measuring wheel speed/direction. the information is posted here:
http://forums.parallax.com/forums/default.aspx?f=25&m=159746
Although it worked really good during my testing, I haven't done much since, but I will try to take pictures of the whole assembly and post it here this week, this idea works with the Propeller, and it should work on a PC based robot (if I recall correctly, you are planning on using a Mini-ATX motherboard)
I hope this helps.... Happy Roboting...!!... Jose
I will look in to your post in a bit.. just dont have the time at the moment.
thanks for responding, and I will be back soon.
IC layout designer
Austin Texas
anyway..
the motors are the exact same thing as what coms with the kit.. only diff is that they are 12v and have a little higher gear.. 200rpm's at the shaft. other then that if you look at the motors in the base kit you would not be able to tell any difference at all.
I was also thinking about this last night and I thought of another idea. what about having a smaller roller that rests on the top of the 2 back wheels? the roller would have a shaft that runs over to the top deck of the base and into some kind of encoder. seems easy but I know its not. but in that way i could use some old electronics from the inside of an older roller ball mouse. hmm..
anyway.. just waitiin on them pics man..
Rontopia
IC layout designer
Austin Texas
I will take the pictures tonight.... I promise...
Post Edited (Joe "Bot" Red) : 7/10/2007 8:18:42 PM GMT
Anyway... after you are done, you simply use the MOUSE.SPIN to read back the values of axis X and Y.... Something I like about this idea is that you can also solder switches to where the button switches are and sense the status of the switches too, if you have a wheel mouse, then you have the possibility to sense 3 switches (the 2-buttons + the wheelmouse press button)... so... you can sense 3 rotary encoders + 3 switches using just 2 pins on the propeller... nice !!!
Happy Roboting!.. Jose
Post Edited (Joe "Bot" Red) : 8/14/2007 5:36:42 PM GMT
