Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Error codes — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Robotics
Error codes
Mike NJ
20
2007-07-08 20:35
edited 2007-07-09 17:24
in
Robotics
I have the BOE-Bot kit, and every once in a while I get a " ERROR 102
Expected Terminating" message. What does this mean? do I have a bad connection.
Thanks for you help...
Bruce Bates
3,045
2007-07-08 22:37
edited 2007-07-08 22:37
Mike -
At what point in time are you, or what are you doing, when you receive that error message?
Bruce Bates
Parallax Engineering
14,406
2007-07-09 00:37
edited 2007-07-09 00:37
There should be a character after the word "terminating" which is the missing character.
Mike NJ
20
2007-07-09 04:37
edited 2007-07-09 04:37
Chapter 2 ,Page 55 I copy the pulseP13Led.bs2 example program and when I try to run it I get a popup message Error 102 expected Terminating, and a ok where I click the mouse
Unsoundcode
1,532
2007-07-09 05:19
edited 2007-07-09 05:19
Hi Mike, do you have both quotation marks around the text
ProgramRunning!
Jeff T
Mike NJ
20
2007-07-09 13:54
edited 2007-07-09 13:54
' {$STAMP BS2}
' {$PBASIC 2.5}
"PulseP13Led.bs2
" Send a 0.13 second pulse to the LSD circuit connected to P13every 2 s.
DEBUG "Program running"
DO
PULSOUT 13, 65000
PAUSE 2000
LOOP
Do I need to put the : after running?
Phil Pilgrim (PhiPi)
23,514
2007-07-09 14:28
edited 2007-07-09 14:28
No, but comments start with a single quote, not a double quote (lines 4 and 5).
Mike NJ
20
2007-07-09 17:24
Thanks Phil
I got it to run like it should. Have to remember not to use a double quote in comments.
I'm new to this, But had BASIC in school 28 years ago..
Thanks again for your help
Sign In
Register
to comment.
Bruce Bates
Jeff T
' {$PBASIC 2.5}
"PulseP13Led.bs2
DO
PULSOUT 13, 65000
PAUSE 2000
LOOP
