VGA colour byte H&V sync bits
The colour white in VGA would be 11_11_11_HV
The higher six bits are colour information which is pretty easy to figure out. The horizonal and vertical sync bits are a bit more mysterious. I've tried setting them to both 1 and 0 and there seems to be no difference in the display. Do these actually have a function?
E3 = Thought
http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! The average PC while browsing the internet typically uses less than 30% of it's potential, why not donate a portion of the rest for cancer resaerch?
The Propeller - in combination with a piece of software called VGA-driver which you are welcome to study - outputs within a not so complex timing scheme 5 signals to VGA monitor:
R,G,B,H,V
H and V are strictly digital and in need for the synchronization of lines and frames
R,G, and B are analogue colour data
The Prop however can output two bits for each color channel only: how this is transfered to the monitor is left to the board design; most boards "mix" those two pins by two resistors (R and 2R) - some hypocrats call this D/A converter...
So the 8 bits you describe become the 5 lines to the monitor.
Equal values of the color channels yield sorts of gray; when you used exactly the same resistor values this coresponds to 11_11_11, 01_01_01, 10_10_10, 00_00_00
But you can of course use a different "DAC" e.g. just using 1 bit for each channel, or use all 6 bits for a 64 level monochromious signal.
Post Edited (deSilva) : 7/11/2007 6:11:23 PM GMT
