How to create a "range". Help with code
I am using x := x + 1 to increment the value of a variable "x".
And x := x - 1 to decrement.
How can I create a "range" for this?
(Suppose the value of x must·stay within the range of 1 to 10)
Thanks.
Tony
Thanks.
Tony
Unrelated to the above range question, however I was also wondering if you could do something like this in Spin.
I have:
snd.StopSound(0) 'stop sound on channel 0
snd.StopSound(1) 'stop sound channel 1
snd.StopSound(2) 'stop sound, channel 2
Is it possible to do something like this:
snd.StopSound(0,1,2) ' stop channels 0,1 and 2 at the same time?
Thanks.
Tony
You could go into the sound object and add another method that does what you want, but you can't just add extra parameters and expect that the compiler would be able to figure out what you want to do with the extra information. There are some programming languages that will allow you to do things like this, but they have very specific rules about how the extra parameters are to be interpreted.
Thanks.
Tony
repeat channel from 0 to 5 'Stops all channels
snd.StopSound(channel)
Works great. I must have over looked it during the first 100 times reading that chapter.
Thanks.
