Closed-State Solenoid Valve (Cheap)
I'm having trouble looking for a normally closed, 12 VDC solenoid valve online. We have a bunch of them in class that costed us only 5-6 dollars a peice. Online, though, on all of the major sites (I'm talking mcmaster, granger, surplus center), they go for astronomically higher. The valves will be used for very low pressure water that simply needs to flow from a reservoir to a collecting tank to balance out salinity. Does anyone have any good sources I can look to?
New Universal Pinch Valve Features Compact Design, Excellent Reliability, and Low Cost
Hudson, MA-Clark is pleased to introduce their new Model PS Universal Pinch Valve. The Model PS pinch valve is solenoid driven and offers excellent reliability in a compact design at a low cost. Available in two way normally open (or normally closed) single tube and three way dual tube·configurations, Model PS pinch valves feature Delrin® tube holders and are designed for 1.6mm ID (3.2mm OD) silicone tubing.
Model PS Universal Pinch Valves are designed for continuous duty, measure 49.3 X 20 mm, and are rated for l2Vdc or 24Vdc. Model PS Universal Pinch Valves also feature a convenient push button manual solenoid override to facilitate easy tube changes.
For more information contact Clark Solutions, 10 Brent Drive, Hudson, MA 01749, Tel. 978-568-3400, Fax. 978-568-0060, e-mail sales@clarksol.com, or visit our web site at http://www.clarksol.com.
Good Luck
John Bond
