Mac USB-Serial controller — Parallax Forums
MonteMonte Posts: 1
edited 2007-07-05 21:15 in BASIC Stamp
Hello all:
I am working on a Mac Core 2 Duo on OS X.4.10. When I run the BS2, the USB-serial adapter (GUC232A) doesn’t show up as an option in the pull-downs, but this plug does show up under the “More Info…” window of the “About This Mac”.
Is this one of the supported serial adapters?
Your advice is greatly appreciated,
-Monte
  • ForrestForrest Posts: 1,341
    edited 2007-07-05 21:06
    All USB to serial adapters aren't created equally - some drivers don't support all of the RS-232 signals which are required to program a Basic Stamp.
    I've tried that USB to Serial adapter on my G4 Mac about 2 years ago and never was able to get it to work with MacBS2. I think the GUC232A uses the Prolific PL2303 chiipset - and there's a an Open Source OSX driver that may work - see here www.muratnkonar.com/otherstuff/macbs2/faq.shtml and get the driver here sourceforge.net/project/showfiles.php?group_id=157692
    Let me know if you get it to work with MacBS2
    I have successfully used a Keyspan USB to serial adapter with MacBS2, and Parallex officially support the FTDI based adapter they sell here
    www.parallax.com/detail.asp?product_id=28030
    +1 to the Keyspan unit, and the FTDI-based unit. Other's CAN work, but might not. One labeled for "PDA" use probably won't work -- PDA's tend to be very sloppy in how they use the hand-shake signals (if they support them at all).
