using the thermo couple
I just got the ds2760 and the temp is about 5 degrees F off from about 3 differant digital thermometers.· I am just using the basic code that comes with the download.· any sugestions?· and also I can't seem to do anything else with the program.· Can the bsp24 monitor more than one thermocouple?· Where can i see a break down of the code already generated?· Lots of questions.· Thanks for your time.
aaron
aaron
Make sure that your thermocouple leads are tight going into the posts on the DS2760 board. I soldered mine in with excellent results. As of yet, I'm unaware of any way to run two thermocouples using the BS2P24. Here is something to do with your thermocouple. http://forums.parallax.com/showthread.php?p=637023
Twisted Pair....
